by Ollie_ Investigator
PAYG £10 Everything Back Data Doesn't Work
Whenever I get the £10 everything pack the data doesn't seem to work, it says 4G in the corner but no webpages will load and the data bar on my account doesn't go down even though it says I have data.
The calls and texts seem to work fine.
8 REPLIES 8
Re: PAYG £10 Everything Back Data Doesn't Work
Try downloading your internet settings and see if that helps.
Thanks,
Where it says manufacturer I don't see the option for Apple to select iPhone 6s?
Hi @Ollie_
Thanks for coming to community 🙂
Have you spoken to the technical team about this at all?
Cheers
Richard
No i haven't
Hi @Ollie_,
Have you turned on mobile data in your settings?
@Ollie_   Have you allowed the apps to use cellular data?  Look in Settings>Mobile Data.
Mobile data is enabled and all apps are allowed to use it.
Hi @Ollie_,
Please get in touch and our technical team will be happy to help.
Recent solutions
