by Jonesg96
New Member
Osprey mini turns on and connects but doesn't work
Hi.
I have an osprey mini. Which turns on and connects to both my Mac and samsung s7.
But when I try to use the internet etc nothing happens. The osprey device is showing a strong 3G signal, I have checked and local signal is fine.
Any ideas?
by Profile closed
Not applicable
Re: Osprey mini turns on and connects but doesn't work
Hello @Jonesg96 sorry to hear you are having problems using your MBB device. When connected to it are you able to view this link:
http://add-on.ee.co.uk
You can also log in to the router to check its settings or reboot/reset it using this link:
http://192.168.1.1
Username and password are usually set to admin/admin by default unless you have changed them or they can also be found on the KEEPMEE card that came with older devices. 🙂
Do you have some data allowance left?
Recent solutions
