by cmcart Investigator
Only 4G & H+ working. 2G & 3G useless
Hopefully someone can help as I'm at my wits end with this one. If I pick up an H+ or 4G signal my data works as it should. As soon as I have a 2G or 3G signal nothing at all will load. I work offshore and I'm often on the edge of receiving a 4G signal. I thought it may be an issue with my phone but got a replacement through my insurance due to a smashed screen. Still have the same issues with new one. I went into a store and got a replacement sim in case that was the problem but again, same issue. When offshore I often put my sim in a 4G dongle for a better signal. Any time it picks up 2G or 3G signal i get an internet not available message. As soon as it drops to H+ or up to 4G it works again. Has anyone ever had this problem and knows a possible solution before I through my phone in the north sea?
8 REPLIES 8
Re: Only 4G & H+ working. 2G & 3G useless
@cmcart    How far of shore are you ?
2G and 3G have a better range from the mast than 4G so if your on the edge of 4G range you will struggle with a signal.
I'm having the same issue when I'm home too. It's not just offshore. Anytime I'm picking up 2G or 3G my data just doesn't function
by Ace Contributor
@cmcart have you tried a replacement sim ?
Have you checked the Network Status Checker there & logged the problem?
Yeah I've had a replacement handset due to a smashed screen and also got a replacement sim but still the same issue
No. As it happens anywhere I'm only picking up a 2G or 3G signal. In the UK or abroad it doesnt matter. It just won't work unless its H+ or 4G. It's really bizarre and I cant think of any way to get a solution
Hi @cmcart,
I would recommend getting in touch with our Customer Care Team so our Tech Gurus can help.
Let us know how you get on.
by Skilled Contributor
Skilled Contributor
Unless it's 4G on 800Mhz of course....
