by peterjenny Investigator
On holiday in Spain, my 4gee WiFi doesn’t work, will not connect to network.
12 REPLIES 12
by Ace Contributor
Re: On holiday in Spain, my 4gee WiFi doesn’t work, will not connect to network.
Hello @peterjenny try performing a manual network search by logging in to the device here:
http://192.168.1.1
Then navigate to connection>network, change to manual and click apply.
Hi @peterjenny,
Thanks for joining the EE Community.
That's great advice from @tm90, please let us know if you manage to get connected.
Sorry will not configure.
Sent from my iPad
by Ace Contributor
Make sure the device status is showing as disconnected in connection>connection status or the option will be greyed out.
Is it a PAYM or PAYG EE SIM card?
It’s a pay monthly device.
Sent from my iPad
by Ace Contributor
Were roaming and call abroad enabled on the account at least 24-48hrs before traveling:
http://www.three.co.uk/feel-at-home
Does it let you search for any networks and none load or is the device giving an error when you try to search?
Morning @peterjenny
Thanks for coming back to us.
Are you able to select any other networks?
Thanks, Leanne.
Hi cannot connect to internet there is a item called Movistar? Comes up but when try to get internet nil.
Peter
Sent from my iPad
Hi no it doesn’t search.
Sent from my iPad
Hi @peterjenny
Thanks for coming back and trying this.
As this has not worked, I recommend logging into your My EE account on your phone's browser (not the app) or a computer.
Once you're logged in, a chat window will pop up when an advisor is available.
If you can't get in contact with chat, please get in touch from an alternative phone.
Thanks, Leanne.
Hi have you the telephone number to call please
Peter
Sent from my iPad
Hello there @peterjenny
If you can call us on +44 (0) 7953 966 250.
Thanks 🙂
