by Kaczan92
On 4GEE Plan 5GB, data runs out, is there a way to top it up?
Hi! I recently moved to a new place and Im literally abusing the data available to my plan, soon its going to run out and I need to survive like this till 4th April.
Is there a way to top up my data with extra data pack? I cant find it anywhere on the website, I think Im blind. Whats is the charge once it runs out?
Thnx!
Solution
Re: On 4GEE Plan 5GB, data runs out, is there a way to top it up?
Hi @Kaczan92,
Welcome to the EE Community.
In the My EE app, tap plan and add-ons, followed by get add-ons.
Hope this helps.
Solution
Hi @Kaczan92,
Hope this helps.
by Kaczan92
Thanks, m8! You saved my life!
Have a great weekend! ❤️
No problem @Kaczan92, you too!
