by Rossykat
Not got a signal!
Hi, can anyone please tell me what time they expect the normal service to resume? Haven't been able to access the internet for a while now (using my PC at work to write this!)
Many thanks.....
7 REPLIES 7
by majid17
Re: Not got a signal!
Same problem pdp failure I think everyone is having the same problem this morning
by Vinnysmrs Investigator
I have signal but saying I have do not have mobile data - I have used 537mb out of my 10gb allowance yet says expired .. due to expire on 17/11/2107 ???
by Rossykat
Thanks Majid.....
by Rossykat
Cheers Vinnysmrs, think everyone is having the same problem!!
Morning all.
Could you all try a quick re-boot of your devices and re-test?
Let me know if you're still experiencing problems.
by Rossykat
It's all good now, so don't have to! Thx for reply tho..... 😊
Sent from my Samsung Galaxy smartphone.
Brilliant, glad it's back to normal @Rossykat. 😄
