by scotty319 Investigator
Not all 4G+ coverage showing on coverage checker
I was just wondering, EE, if all your 4G+ coverage is showing on your coverage map?
For a while, the area in the red circle was showing as having 4G+, but this has now disappeared?
When doing a 4G download speed test, the speeds are incredibly fast and must be 4G+. I got speeds of around 220Mbps download.
The area is Longwell Green, in Bristol.
Thanks!
Re: Not all 4G+ coverage showing on coverage checker
The coverage checker is a guide and EE are unfortunately slow to update it.
by Skilled Contributor
Skilled Contributor
There is L2600 deployed around Longwell Green, for what it's worth. Oh, and as for the coverage map being slow - you try searching against Portree the main town on the Isle of Skye. According to the map, it's 2G only. There's been blanket 4G there since at least September.
Recent solutions
