by SianL23
Not able to use data to use internet although I have 4g signal
Not able to use data to use internet or apps although I have 4g signal. I’ve recently returned from holiday and have checked network settings are they are same as they were before. Can anyone help?
Re: Not able to use data to use internet although I have 4g signal
Hi @SianL23
If you have an iPhone then try resetting your network settings.
Also log into your MyEE app and then under settings - Content lock - change this to off.
Restart your device.
