by Jennii
No signal
I have had no signal now for 24 hours.
I have done everything I can.
Phone on and off, removed sim, checked for works in my area, airplane mode on and off, updated my phone. Nothing works.
 I am fully up to date with.my contract so no payment issue's.
Also my single came back for 1 min at most when I restarted it once but after that nothing.
Please please please help as I use my phone for work
Re: No signal
Can you try your sim in another phone as it sounds like either your sim or your phone maybe the problem if you have checked and there are no network issues
Where did you get your phone and what make/brand is it?
Thanks,
Re: No signal
Hi @Jennii
Did you get a chance to check out the status checker that @Northerner referred to?
That will advise you if there are any known issues in the area and allow you to report a problem too.
Please let me know how you get on.
Chris 🙂
