Highlighted
by Investigator
No signal in my house
I have just moved into a new build flat and have absolutely no 4G or even 3G when indoors. The flat is in a built up area so I don’t understand why I can’t get any service? Can anyone help? I have used the coverage checker which shows I should get good coverage.
Highlighted
Re: No signal in my house
@Laura89xx  EE can not guarantee your signal indoors due to different construction methods in buildings.  The network signal guide is not a guarantee of signal it’s just a guide as stated on the guide.  Can you not use the WiFi calling service?
Highlighted
Good Morning @Laura89xx.
Welcome back to the community.
What phone are you currently using?
If your phone is compatible, @Chris_B's suggestion of WiFi Calling would be a great way to use your services indoors.
Could you check your area in our Network Status Checker?
Hope to hear back form you soon.
Jon
