by CKsite_1
New Member
No data
I have been struggling with no data network work over a week now. Not sure what to do.
by Star Contributor
Star Contributor
Re: No data
Hello and welcome.
Just so we can help get to the bottom of your problems, it would be helpful to know If your data work elsewhere, what your phone says next to the signal bars (G, GPRS, E, H, 3G etc) when this happens.
Would you also be able to provide most of a postcode (or all of you’re happy) so we can check for issues.
by bjenb Investigator
Re: No data
I haven’t been able to use data for a over week now only used under a tenth of my package which runs out next week my postcode is Ta94ab
Re: No data
Hi @bjenb
Checking EE Network Status page and it says:
NO KNOWN PROBLEMS INTA94AB
Network should be fine here. If you're having problems, flag it up and we'll investigate. Problems reported in the last hour may not appear straight away.
It may just be that you are in a poor signal location because of the buildings.
Re: No data
Hi @CKsite_1
Welcome to the community. 🙂
If you usually have good signal there, I recommend reporting a problem on the status checker that @Northerner referred to.
That way our technical teams can investigate any problems.
