by Jacobspruce Investigator
No data
I am currently in the USA and yesterday I tried to buy an add on but it didn't work and I don't know if that has anything to do with it but, I think my plan restarted today and I went into the app and it doesn't say I have any data and I went online and it says I have 0.1mb out of 0.1 mb to use when my plan is 5 gb
8 REPLIES 8
Re: No data
Hi @Jacobspruce
Thanks for coming to community from America 🙂
Does your plan include data use in the USA?
Cheers
Richard
Re: No data
No it doesn't but I bought the day thing and didn't even use it and then I woke up today and my data is all messed up
Re: No data
Hi @Jacobspruce,
What happens when you try to purchase an add on?
Do you see a particular error message?
Re: No data
Hi! No no error messages it just said it was all successfully but I couldn't use the internet. I am just worried about why my app and online it says that I have no data to use when I get back to the uk
Re: No data
Hi @Jacobspruce,
If your data allowance doesn't correct itself when you return to the UK, please get in touch with customer services.
Re: No data
Okay yeah will do thanks, should it just do that and go back to normal when I get to the uk?
Re: No data
Hi @Jacobspruce,
Yes, it sounds like a temporary glitch.
Please let us know if you have any further problems.
Thanks Smiley Happy
Re: No data
Will do thank you
