by maestra
No data in Italy
I have received a text from EE on 150 saying data roaming is in place, i have revived texts saying it's working, I can text and call but no internet usage? No option to enable data roaming as greyed out? Very frustrated! Turning phone on and off doesn't help?!
Re: No data in Italy
What phone do you have?
You should be able to activate roaming on your handset under network settings.
Hi @maestra
Welcome to the community, I hope you're having a fantastic time in Italy. 🙂
Please try the troubleshooting below and let me know if any of it works:-
Try re-booting your device
Try turning 4G off in ‘settings’
Perform a manual network search:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Look forward to hearing from you.
by maestra
Hi, finally got it sorted thanks anyway!
Sent from my iPhone
Brilliant, @maestra.
I hope you enjoy the rest of your time in Italy. 😄
