by Lorchris
No 4G (or any mobile data) on A8 - any ideas? turned off and on, reset phone
Solution
Re: No 4G (or any mobile data) on A8 - any ideas? turned off and on, reset phon
@Lorchris  I would call customer services as the checker only shows known issues and it might not yet have been updated.   If your device was ok yesterday in the same location then I highly doubt it’s a device issue.
@Lorchris  Please put your postcode in to THIS to see if there is a known issue in your area.
by Lorchris
thanks - did that earlier and no issues 😞
Solution
Morning @Lorchris
Can you make calls and send texts?
Is this happening in other areas?
Speak soon, Leanne.
