by Northy91 Investigator
No 4G / Data - PDP authentication failure
I have just got a iPhone 7+ and an EE sim early yesterday.
The phone does not seem to be able to get its data connection, its a couple of hours over the 24 hours i have had the phone in and connected now but when i try to use data it shows a message
" could not activate mobile data network, PDP authentication failure "
I have turned the phone off and on
I have reset the network settings via the general>reset>reset network settings
I have updated to latest ios version
I have reseated the sim
I have a carrier profile from what i can tell in the settings
I can make calls and send texts without any issues it just appears to be data that is affected.
Any advice would be appreciated, l am a little disappointed that my first couple of days of being EE i am facing issues.
Solution
Re: No 4G / Data - PDP authentication failure
Hi @Karen_C and @Chris_B
Thanks for your assistance, this has now been resolved spoke with EE support and they took the digits from the SIM and hey presto working.
10 REPLIES 10
@Northy91  Connect the device to iTunes on a PC and click restore.
Hi @Chris_B
I have just restored the phone now but no joy am afraid.
Cheers for your help
@Northy91  Ok. Can you turn off wifi on the device and do a network reset.  Settings>General>Reset>Reset Network Settings.
You will ned to put your wifi passwords back on the device when you need to connect to wifi but at the moment leave wifi off.
Morning @Chris_B
tried doing that already buddy, tried it again though just in case still to no avail
cheers
@Northy91  Just to check mobile data is enabled on the device?
Yeah @Chris_B
mobile data is turned on
i have tried selecting another operator in my area which doesnt help
i have restarted the phone and reseated the sim again
Double checked the coverage for my area and i am supposed to be able to get 4GEE and the phone is showing max signal
cheers
@Northy91  it sounds like you might need to call customer services and ask them to reset you line.
EE Employee
Morning @Northy91
If you're a personal customer you can use the live chat link on the get in touch page.
Tech support will be able to do a refresh from our side - that should get your data up and running.
Pop back and let us know if you need anything else!
Thanks - Karen. Smiley Happy
Solution
EE Employee
Fantastic! Smiley Very Happy
Thanks for popping back to let us know.
Have a great day!
