by DanV Investigator
Nintendo Switch Mobile Hotspot issues
I can connect my Mobile Data Hotspot to my nintendo switch and browser the store, download games and do basic tasks but when it comes to connecting to online games I get errors usually including NAT Traversal Error and similar things, any help?
8 REPLIES 8
Re: Nintendo Switch Mobile Hotspot issues
Hi @DanV
Welcome to the community.
What kind of device are you setting up the hot-spot from?
Can you check to see if you get full connectivity when connected to WiFi?
I’m using my iPhone SE as a hotspot and it is connected full after multiple times
Ah brill, glad it's sorted, @DanV.
What game are you playing?
We've got a gaming section of the community, if you need any help with anything gaming related in future. 🙂
No unfortunately it’s not sadly because I still cannot connect to online matches but when testing connection in the settings it says it’s connected fine
Ah, I see what you mean, @DanV
Are you able to try using your Nintendo switch on a different WiFi connection or not?
Yes I've connected it to multiple other connections and it works fine
OK, thanks @DanV
I recommend speaking to our Tech Gurus to see if there is anything that they can do to help.
Please let us know what happens.
Will do. thanks
