by MrMagicMart Investigator
Newbie pulling my hair out with Cisco signal box
Evening all this is my first post I joined yesterday and my area has shocking signal no bars in or outside they set a signal box made by Cisco and call by assist  it was put in at 4 pm today and calls are working now working however 3G and data are not I have tried the delete network I reset signal box I restarted and reset network setting on phone I have an iPhone XS Max and partner has a iPhone 7 also son has a Nokia all doing the same spoken to tech team they don’t know why it doing it,  as everything looks good there end but it can’t be. Our house don’t use Wi-fi as we are fully hard wired so need the 3G data connection  they not state it’s cos a mask is down at the moment however I don’t belive this as there are no masks in the village and if there was why would a signal box use a mask?? ALL I WANT IS MY 3G anyone plz help4B01BAE2-78EE-4261-82D8-449CC76912A9.png
7 REPLIES 7
by Ace Contributor
Re: Newbie pulling my hair out with Cisco signal box
Hi @MrMagicMart
Welcome to the EE Community,
there seems to be a common problem with the signal box and the iPhone XS  I would recommend speaking to technical support on freephone 0800 956 3146 from a landline.
I have and they have no clue  it’s also same issue with Nokia and a iPhone 7 Plus
by Ace Contributor
@MrMagicMart I would try them again
I seem to remember it's something to do with an incompatibility between the iPhone using IPv6 but the Signal Box only using IPv4. If you could somehow change the APN Protocol to IPV4 Only in the phone's APN, that might fix it. I think some users have had to create a 2nd APN with that value as the default one can't be altered.
Ok this will be the 4th call to them
How and where about do I find this
Good Morning @MrMagicMart
I am sorry to hear this is still not resolved.
I have sent you a private message for further information, please take a look and get back to me.
Thanks, Katie 🙂
Recent solutions
