by KayJW Investigator
New SIM 4G not working
Everytime I try switch on my 4G a message keeps coming up saying "Could not activate mobile data network, You are not subscribed to a mobile data service". What does this mean? How do i make my internet work? This is a new SIM that i got and put in my phone 2 days ago.
Re: New SIM 4G not working
@KayJW   Have you restarted the device?  Is cellular data enabled on the device?  Have you allowed the apps to use cellular data ?
Hi @Chris_B , yes i have restarted the device, cellular data is enabled and i have allowed the apps
Good Afternoon @KayJW
Are you currently in the UK?
Was this SIM a replacement?
Are you able to make calls and texts ok?
Speak soon,
Katie 🙂
Hey @Katie_B
Yeah I’m currently in the UK
Kind of as I had a T-Mobile sim before which was pay as you go, so it is kind of an upgrade from that
Yes I’m still able to make calls and text
Hi @KayJW
Thanks for confirming.
I would recommend getting in touch with our technical care team.
Please keep me updated with your progress,
Katie 🙂
