by Trucktriple6 Investigator
New HTC ultra on ee intermittent data connection.
I have performed a factory reset on the phone and also reset the apn settings.  Don't know if handset issue or EE issue.  Problem is very intermittent though sometimes I have internet sometimes I don't
7 REPLIES 7
Re: New HTC ultra on ee intermittent data connection.
Are you PAYG or monthly contract?
Have you tried downloading your settings here.!
EE Employee
Good Morning @Trucktriple6
You may need to enter the internet settings manually.
Try these settings;
Name Internet
APN everywhere
Proxy Leave Blank
Port Leave Blank
Username Leave Blank
Password Leave Blank
Server Leave Blank
MMSC http://mms/
MMS Proxy 149.254.201.135
MMS Port 8080
MCC 234
MNC 30
Authentication Type PAP
APN Type If you have choices select internet + mms otherwise type in *
Let me know if this helps!
Thanks - Karen. Smiley Happy
I looked at this yesterday unfortunately settings for the HTC ultra are not in the list.
I'm a pay monthly contract.  I have tried both APN reset and download of settings with no results. As a last resort I factory reset the phone last night and still no joy.
EE Employee
Hi @Trucktriple6
Did you try adding the APN manually?
You sad in your first post that sometimes you can access the internet - have you checked The Network Status Checker to see if there's any issues in your area?
How long have you been experiencing issues for?
Speak Soon!
Cheers
Karen. Smiley Happy
There are no issues in my area and it happens in multiple geographic
locations.
Sometimes switching from WiFi to 4g causes the issue and sometimes 4g has
worked fine then stops for no apparent reason.
I can be using an app in a fixed geographic location and 4g will stop for
no visible reason.
Thanks for the information @Trucktriple6.
In this case our technical support team will need to get this looked into for you.
If you use our get in touch pages and select EE you will have the option to chat to a technical support agent.
Let us know how you get on 🙂
