by dthomsonn Investigator
New Customer - IPhone 7 Plus Data Not working
Hi
I recently joined EE and originally had an issue with data not working, so I reset network settings. This worked for the rest of the day. Next morning it was back to square one and not working. To cover what I've done; I have reset network settings again numerous times, went in and out of airplane mode, went into airplane mode - switched off and on - then came out of airplane mode, the previous two steps but removing SIM card. I don't know what else to do, I have checked google and nothing helps. Can anyone help out?
Re: New Customer - IPhone 7 Plus Data Not working
@dthomsonn   Have you called customer services and ask them to reset your line ?
