by Amanda10
Need to up my data
I'm going over my data allowance most months due to having to use 4g when out and about.
I never use all my calls or texts on my plan and would rather have more data and less of those!
How do i go about getting a bigger data allowance?
Thanks Amanda
by Brilliant Contributor
Re: Need to up my data
You will need to go up a tariff you can't reduce calls or texts and just increase data.
You will have to pay what the tariff states.
You can't pay less through so once you up the allowance and price you can't go back down.
Hi @Amanda10
Welcome to the community. 🙂
As mentioned above, you can change your plan, even if you're in-contract.
Find out more about changing your pay monthly price plan >
Find out more about pay as you go packs >
Hope this helps
Chris 🙂
Recent solutions
