by Am1r Investigator
My mobile network is bad and so is my 4g? And yes I have restarted my phone.
7 REPLIES 7
Re: My mobile network is bad and so is my 4g? And yes I have restarted my phone.
Bad in what way? Slow? Unreliable? Non-existent?
Have you checked the Network Status Checker  ?
Well my network is always on one bar and 4g is very slow in my area where I live. Is there any chance EE can sort out the issue? I don’t have a problem in any other areas.
Did you check your Network Status? It can keep you posted on any issues in your area.
Yes I have checked my network status. It says may experience some issues? I have just recently joined EE and I have to say I’m quite disappointed. They should sort this out.
by Profile closed
Not applicable
Hi, @Am1r,
As far as i'm aware, masts in some areas are undergoing maintenance and being upgraded! This should be finished soon! 😊
Regards
mAh8v
by Star Contributor
Star Contributor
Where is this happening?
What device do you have?
Hi there @Am1r
Thanks for coming to the community, I'm sorry to hear you are having signal problems.
Have you registered for updates on the EE Network Status Checker?
Are you with us on pay as you go or pay monthly?
Leanne 🙂
