by clogue
New Member
My mobile data isn't working. I'm not sure if my data has run out or just fault?
Current period and data roaming both 0.
by Profile closed
Not applicable
Re: My mobile data isn't working. I'm not sure if my data has run out or just fa
Hello @clogue you can check your data allowance by texting the code AL to 150, logging in to MYEE either online or through the app or using this link from your phones data (not WiFi) connection. :):
http://add-on.ee.co.uk
