by Nikki611
My data will not work outside a wifi area
My data is not working outside a wifi area. I have a 30gb allowance and apparently I have 28gb left however when I leave wifi areas my phone says you have no wifi???
Re: My data will not work outside a wifi area
@Nikki611   When out side of a WiFi area you need to have cellular data enabled.  You need to make sure your apps have been allowed to use cellular data on your phone.
by Nikki611
Yes they do, this has happend all of a sudden today. It's been fine up until now
@Nikki611   Try cleaning the sim with a damp cloth.  Make sure it’s dry before you put it back in the device.  And to check do you have the EE signal showing on the device ?
