by Foster75 Investigator
My data reset has not worked, I have tried turning off and on and resetting ???
Help! My data should of reset yesterday but hasn't, I've tried turning the phone on and off and taking the data usage off and re-setting that but no luck. My phone did have a melt down during the month when an update made it overheat and I had to turn it off and on so I'm not sure if that has affected it ???
EE Employee
Solution
Re: My data reset has not worked, I have tried turning off and on and resetting
Hi @Foster75
In order to use the data it will need to be kept on, you will not incur any additional charges as when you run out you will be prompted to buy more.
Many thanks,
Lee
17 REPLIES 17
@Foster75  Your device will have no effect on your data allowance.  With wifi off on the device click THIS and it will show you exactly what data you do have.
Hi Chris,
I have tried this with no joy 😞 any other suggestions ???
EE Employee
Hi @Foster75 and welcome to the Community.
Did you purchase a bundle before your renew date?
Many thanks,
Lee
Hi Lee
No I don't think so, I only purchased the phone last year
Sarah
EE Employee
Hi @Foster75
I think there has been some confusion in my question.
Last month did you run out of you standard data allowance and purchase a bundle to see you through to your billing date (Yesterday)?
Many thanks,
Lee
Hi Lee
Yes I did run out but I didn't buy any extra data
EE Employee
Hi @Foster75
What response do you receive when you text AL to 150?
Many thanks,
Lee
Hi Lee,
It says I have 300MB remaining of my data allowance, it says the same when I log into my online account and check my data allowances ( 300 MB left of 300 MB bought 9th Feb )
Sarah
EE Employee
Is that the correct amount that you should have @Foster75 ?
Many thanks,
Lee
Yes I get unlimited texts and 300 uk and voicemail calls and 300MB
EE Employee
@Foster75
Is your device not allowing you to connect to any data service?
Many thanks,
Lee
No, no emails for facebook messenger or interent
EE Employee
Hi @Foster75
As the suggestions have not worked, I have generated you a unique chat link to our customer service team, who will be happy to look into this for you.
This can be found in your Private Messages.
The link will be active from now till 9pm (UK TIME).
Let me know how you get on.
Many thanks,
Lee
Hi Lee,
Sorted now I think my account was refreshed and lots of turing things off and on , but quick question, on the mobile data/data connection on settings, it says mobile data may be used in the back ground and may incurr charges, turn it off to avoid additional charges. If I turn mine off now, my data used is incorrect again. Do I now have to leave it on all the time ???
EE Employee
Solution
Hi @Foster75
Many thanks,
Lee
O.K that's great thanks for your help 🙂
You'd best turn background data OFF. This is data used by apps in the background for their own (not yours) nefarious purposes. This will not stop you using your apps explicitly on demand and then they will be using foreground data as necessary.
