Highlighted
My data keeps dissapearing
hi,
i had to buy buy extra data that runs out today but I got a txt last night saying my data will renew next month??? It’s like it’s being used up and drained, all my services are turned off eg vids for Facebook and WiFi services do not sure what it could be, please help
Highlighted
Re: My data keeps dissapearing
Hi @Damoc83
What device do you have?
If you check under your data app (normally under settings) then it will tell you what is using your data.
Thanks,
Highlighted
Hi @Damoc83
Welcome to the community.
@Northerner has already posted the advice I would have offered.
If you let us know what device you have, we'll be able to give you more detailed instructions.
Find out more information about how to check how much data you're using >
