Highlighted
My current EE Data
How to check my current EE data package availability, pls?
Highlighted
by Ace Contributor
Solution
Re: My current EE Data
Hi @AnnaEE
http://add-on.ee.co.uk
Check with above link with your mobile data.
You can also check your remaining allowance via text AL to 150 with EE App or with EE Web account
Highlighted
by Ace Contributor
Solution
Hi @AnnaEE
Highlighted
thanks Tahirmian!
