by ErikaS888 Investigator
My cellular data doesn’t work
Hi!
 I m on contract and in the past two months I had problems with my data! I cannot use lots of my apps (including messenger or Facebook) when I m not connected to wifi. I have tried everything already
what else can i do?
thank you
Solution
Re: My cellular data doesn’t work
Hi @ErikaS888.
Welcome to the community 🙂
Could you try turning your content lock back on, then restarting your phone, then removing it again?
This will usually trigger the data to work again on these apps.
Jon
Hi @ErikaS888
Try removing content lock.
Try logging into your MyEE app then - Settings - Content Lock - change this to off. Then restart your device.
It should now work.
Thanks,
Thank you for your reply.
I have checked already and it s off...:(
Solution
Hi @ErikaS888.
Jon
It worked 😅thank you very much
That's great, @ErikaS888!
Thanks for coming back to let us know 😁
Jon
