by Claire1772
My additional data has disappeared
I purchased 5 GB data add on when I went on holiday 10/9/18. Only used 45% and its disappeared now my monthly plan allowance has restarted!
by Ace Contributor
Solution
Re: My additional data has disappeared
Hi @Claire1772
You add on only stay till you allowance renew.
You can find this information
  • It lasts until your data allowance refreshes at the start of your next bill date, and will not be carried over
  • Any allowance data you've got left gets used first
Here http://add-on.ee.co.uk/purchase
Under important stuff.
by Ace Contributor
Solution
Hi @Claire1772
