Highlighted
My Instagram and Facebook Apps won’t work on 3G/4G but are fine on WIFI.
My Instagram and facebook apps won’t work on 3G/4G but are fine on WIFI. All my other apps work fine with 3G/4G. My content lock is on the right setting and in settings on my phone both Instagram and Facebook have mobile data turned on.
7 REPLIES 7
Highlighted
Re: My Instagram and Facebook Apps won’t work on 3G/4G but are fine on WIFI.
Hi @Charlottemoore2
Your content lock cannot be deactivated. Check again on your MyEE app, then restart your device.
Highlighted
by Profile closed
Not applicable
Hi @Charlottemoore2
Please! Follow these steps!
Go to your online EE account and switch your content lock to STRICT and then reboot your device, once done, return to the content lock and switch it OFF!
Would you do that for me, please! It should fix everything!
Please let me know if this works ? Ok!
Cheers 👍
BustaCrabb 🦀
Highlighted
Hey.
Thanks for this but I have just tried it and it’s still not working.
charlotte
Highlighted
by Profile closed
Not applicable
Hi @Charlottemoore2
Ok!
Can you repeat the step's and this time DON'T reboot your device and see if that's any better ?
Thanks 👍
BustaCrabb
Highlighted
@Charlottemoore2
You will need to call CS on 150 and have them look at your account. It maybe you need to prove your age.
Highlighted
by Profile closed
Not applicable
Hi @Charlottemoore2
The only other thing I can suggest is following @Northerner's advice and giving CS a call!
Cheers 👍
BustaCrabb 🦀
Highlighted
by Profile closed
Not applicable
Hi @Charlottemoore2
Did you manage to get thing's sorted by the suggested advice above ? Or CS ?
BustaCrabb 🦀
