by gru
My EE everything pack has 2 Gb, but my friend's everything pack has 7.5 Gb.How?
How is it possible? Why don't I have 7.5 Gb?
by Profile closed
Not applicable
Solution
Re: My EE everything pack has 2 Gb, but my friend's everything pack has 7.5 Gb.H
Has your friend just not got more EE free boosts though and they have chosen the extra data free boost, which everyone on EE PAYG starts getting after their 3rd top-up?
More info about PAYG boosts here.
I don't think there's a limit to how many free boosts you can get.
@gru   Are you sure he hasn't purchased extra data ?
what does his account say ?
by gru
@Chris_BYes, I am sure. As I can see on his profile, his £5 pack has 5.6 Gb, £10 — 6 Gb, £12.50 — 6.5 Gb, £20 — 8.5 Gb etc.
@gru. Then lucky him as this shouldn't be the case.  And if you call customer services about this they'll pro want to take a look themselves and then they probably reset his account so it's correct.  You have the power to say nothing or you can stick one over on your mate.
by Profile closed
Not applicable
Hello @gru how long has your friend been on PAYG? If you saw this on the 'pack & add ons' screen from their MYEE account online this is because they have collected 5.5 gb free boosts (11 data boosts) so far. 🙂
by Profile closed
Not applicable
Solution
Recent solutions
