by eviethomas0 Investigator
My 4g won’t work but I have plenty of gigabytes remaining? Please help
Re: My 4g won’t work but I have plenty of gigabytes remaining? Please help
Hi @eviethomas0
Welcome back to the community.
What phone are you using?
Can you make calls and send texts?
Also, do any problems show in the area on our Network Status Checker?
Hi thanks for your help I have an iPhone X and I can send text messages!! My area is not yet been put on the server so I’m not sure.
Sent from my iPhone
Hi @eviethomas0
Thanks for the quick reply.
Can you try and reset the network settings to see if this helps?
This will delete any saved WiFi passwords.
Go to Settings > General > Reset > Reset Network Settings.
Have you been able to use data on the iPhone before?
Leanne 🙂
