by antnkel1 Valued Contributor
Valued Contributor
My 4g download speed is poor
My 4g download speed is only ranging from 5gb-15gb and my upload is 0gb!
27 REPLIES 27
Re: My 4g download speed is poor
@antnkel1  Have you tried clearing any apps from the background and perhaps even restarting the device?
Valued Contributor
Yes, done that. Did a speed test at home last and it's fine, its just when I'm at work the speed is appalling.
There's supposed to be coverage here but no upload speed at all.
Good Morning @antnkel1.
Welcome to the community.
Have you checked the postcode in our Network Status Checker?
Jon
Valued Contributor
Hi, yes I have. It said everything is fine, but obviously not!. No upload speed at all!
Thanks for checking @antnkel1.
I'd recommend contacting our technical support team about this so they can have a further look into the postcode.
Come back and let us know how you get on.
Jon
Valued Contributor
Will do.
by Star Contributor
Star Contributor
Could I get a postcode for where you work or nearby?
Valued Contributor
Of course, its BB186EP
by Star Contributor
Star Contributor
You appear to be very between sectors there. Just to try and assist ruling out a highly loaded site, some info from field test could be useful. Are you on Android or iOS?
Valued Contributor
Android
by Star Contributor
Star Contributor
In that case, apps like cellmapper, G-NetTrack lite will say the eNB of the site you're connected to and basic signal information like SNR.
Valued Contributor
Not sure what I'm looking at but the
enb is 22217 cell 0 lte -106dbm
by Star Contributor
Star Contributor
Signal to noise ratio?
Valued Contributor
MCC234 MCN30 TAC46112
Valued Contributor
30DB
by Star Contributor
Star Contributor
Seems oddly high considering your RSRP is at -106 but some devices misread.
You're connecting to Park Hill Reservoir, a Nokia site, roughly in boresight.
Is performance that bad all the time you're there or does it vary by time?
Has it always been that bad?
Valued Contributor
Only had this phone and SIM a few weeks, it just seemed to be slow so tested it and best I get in this area is around 15mb for download and upload is pretty much 0mb all the time. I tested speed when I got home and the best was 69mb download and 34mb upload.
Valued Contributor
signal to Noise ratio has dropped to 8
dB
Valued Contributor
Changed again now 40db
