by Charlx97 Investigator
My 4G isn’t working
Checked my data usage and still have plenty left yet my 4G won’t work apps not loading and saying no connection help?
15 REPLIES 15
by Profile closed
Not applicable
Re: My 4G isn’t working
Hi, @Charlx97,
Could you try restarted your device, please! 🤗
Cheers
BustaCrabb
I tried that and still won’t work
by Profile closed
Not applicable
Hi, @Charlx97,
And did you remove the Sim card? 🤔
BustaCrabb
Have you checked the Network Status Checker there & logged the problem?
Yes tried that and still nothing
Yes I checked there and says no known problem
Hi @Charlx97
What phone are you using?
Can you make calls and send texts?
Leanne 🙂
Hello yes I can text and call just my apps won’t work and says no connections. It’s the iPhone XR
Hi @Charlx97
Thanks for coming back to me.
Can you try a network reset on the device?
Go to Settings > General > Reset > Reset Network Settings.
This will remove any saved WiFi passwords.
Leanne 🙂
Yes I already tried that and still won’t work
by Profile closed
Not applicable
Hi, @Charlx97,
This may be a totally wild guess, but I'm wondering if your social media apps aren't working, it could be another content lock issue, but please don't take my word for it, as said: this is a wild guess!!
Cheers
BustaCrabb
How do I fix this?
by Profile closed
Not applicable
Hi, @Charlx97,
You'll need to pop in to your online EE account and switch the content lock to STRICT and back OFF again! This should finally fix your issue with the social media app 🤞
Cheers 🤗
BustaCrabb
It worked! Thank you
by Profile closed
Not applicable
Hi, @Charlx97
That's fabulous news!🤗
Thank you so much for letting us know!
Take care and have a great bank holiday w/end 👍
Cheers
BustaCrabb 🦀
