by Mikekadi Established Contributor
My 4G is very slow
I’ve got a 4G signal but I’ve done a Speedtest and it’s around 1.5-2Mbps and considering I’m on the max plan 100gig a month it’s not good
Re: My 4G is very slow
Have you checked the Network Status Checker  ?
Yeah it doesn’t say anything is broken or down
by Ace Contributor
@Mikekadi I’ve had this happen a few months ago and the network checker didn’t state an issue, and others were not having this issue in my area.  I was dipping between E and 4g all morning then decided to turn my phone off completely for a short time out of frustration. ( I never turn mine off usually at all, it’s constantly on ). When I turned it back on,  it was back to normal speeds. Not saying it’s a fix, but worth a try.
Hi @Mikekadi
I see @Watkins07 has offered a great suggestion here.
Did that help at all?
Are you aware of any other users in the area having similar problems?
Recent solutions
