by myoldpal20 Investigator
My 4G is not working on Sony Xperia XZ Premium
Hi
I have recently bought a second hand Sony Xperia XZ Premium, locked to EE.  4G and WiFi calling both working fine, but 4G+ isnti working despite me living in a 4G+ area.  There are no network problems in my area.  Can someone please help me fix this as I am paying for EE's fastest speeds and I can't get them.
Re: My 4G is not working on Sony Xperia XZ Premium
What SIM have you got in it? I'm guessing, as it's 2nd-hand, you have got hold of a PAYG SIM. EE PAYG SIMs don't go up to 4G+ but only 4G.
How is it that you are paying for EE's fastest speeds? What exactly are you buying off EE?
by Ace Contributor
Hello @myoldpal20 it may need enabling now you have a supported device if this is originally a SIM only plan or it came with another none supported device at the start. Either customer service or Live Chat can check for you from 8am:
http://ee.co.uk/help/get-in-touch
Before you do that check your area using the Network Status Checker to make sure there are no known faults or planned maintenance ongoing:
https://myaccount.ee.co.uk/networkchecker/checkservice
by Star Contributor
Star Contributor
Devices with an EE ROM do not display the 4G+ symbol. However, you will still be getting the same network just not the special symbol.
Hi @myoldpal20
Thanks for coming to see us in community 🙂
I can see you've been given great help from @XRaySpeX @tm90 and @Peter_C
Hope this has all helped you.
If you need anything else from us, just shout.
Cheers
Richard
