by beckychud Investigator
My 4G doesn't work anywhere, hasn't worked for the last 2/days
My 4G doesn't work,  hasn't done for last 2 days,  I still have 2GB data and the 4G symbol is displayed
6 REPLIES 6
by Profile closed
Not applicable
Re: My 4G doesn't work anywhere, hasn't worked for the last 2/days
Hello @beckychud what phone do you have?
You can check your area for any faults or planned maintenance by entering your postcode in the Network Status Checker:
https://myaccount.ee.co.uk/networkchecker/checkservice
You can also sign up for My Places just below to receive text updates from EE. 🙂
Thanks for helping @Profile closed
Morning @beckychud.
If you can let us know what device you have?
We will see what we can do to help 🙂
Thanks, Leanne.
Thanks for the help, I have a Samsung S7 Edge
Thanks @beckychud
What happens when you try and access data?
Have you checked the network status checker to see if any problems are showing in your area?
Speak soon 🙂
When I try to use that data it just says no internet connection or can't load this page.
Yes I have checked the signal checker and it says everything is fine here.
Thanks @beckychud,
Can you try this for me.
Go to Settings > Data Usage, Is this showing as ticked?
Speak soon 🙂
