by Keego
Mobile data
My apps won't connect to mobile data but are fine when WiFi is activated. All data settings seem correct.
I've tried uninstalling and reinstalling the apps and even completed a factory reset to no avail. This occurred about 4 days ago and hasn't been right since.
by Profile closed
Not applicable
Solution
Re: Mobile data
Hi @Keego
This could be a content lock related issue!
Go to your online EE account and switch your content lock to STRICT and back OFF again, please! 🤗.
This should fix your issues!
Please let me know if this works ?
Cheers 👍
BustaCrabb 🦀
by Profile closed
Not applicable
Solution
Re: Mobile data
Hi @Keego
Cheers 👍
BustaCrabb 🦀
by Keego
Re: Mobile data
Bustacrabb that seems to have worked.
Many thanks!!! 😁
by Profile closed
Not applicable
Re: Mobile data
Hi @Keego
As long as it worked, you shouldn't have any more issues, fingers 🤞
You know where we are if any more problems arise!
Thanks for letting me know @Keego
Cheers 👍
BustaCrabb 🦀
by Profile closed
Not applicable
Re: Mobile data
Hi @Keego
Thank you 🤗
Glad I was able to help you! 👍
Cheers
From
BustaCrabb 🦀
