by VreceHnoja
Mobile data
Mobile data from ee not working in my new phone. Mobile data is enabled. Mobile data from other sim do work on the same phone if switched. Tried restart. And i still have unused data available.
6 REPLIES 6
Re: Mobile data
  1. Try manually searching for EE network.
  2. Try the online set up tool to update your phone's APN settings automatically and hassle free.
by VreceHnoja
Re: Mobile data
2. My phone is called NOA N5 which is not in those options ^^. 1.  And how to manualy search for ee network ?
by VreceHnoja
Re: Mobile data
2. My phone is called NOA N5 which is not in those options. 1.  And how to manualy search for ee network ?
Re: Mobile data
Hi @VreceHnoja
What network frequently does it use. Also is it dual SIM? And have you set it up correctly?
Are you on PAYG or pay monthly? If PAYG have you paid for data add on/data?
by VreceHnoja
Re: Mobile data
T mobile or orange since i am abroad but , dual sim, payg data available, checked in my ee app
Re: Mobile data
Where abroad?
