by Matthewdriver
Mobile data
Hi i brought my samsung s7 edge yesterdaty but have no 4g my APN was set to virgin but ive reset to ee internet anywhere also tried everywhere turned phone off and on still nothing please help
by Ace Contributor
Re: Mobile data
Hello @Matthewdriver have you got mobile data turned on? Is there a 2G/E/3G/4G icon next to your signal bars? EE APN settings:
Name - EE
APN - everywhere
APN Type - default
Sign in Type - PAP
IP Type - IPv4
MCC - 234
MNC - 30
All others can be left blank or set to default.
by Ace Contributor
Re: Mobile data
HI, @Matthewdriver
Please click on this link http://setup-ee.wdsglobal.com/internet?step=manufacturerselection.vm&contractId=230&countryId=36&net...
Put your phone number and fallow instructions on page and you will receive Internet settings on your mobile save them.
Hopefully it will work for you.
EE Employee
Re: Mobile data
Hi @Matthewdriver and welcome to the community.
Are you able to call and text on the device?
Many thanks,
Lee
Recent solutions
