by alldoj Investigator
Mobile data- working on 3G but not 4G
My iphone SE has been driving me mad for the last couple of weeks.
I started to get a message saying that I could not access the data network- nothing to see on the handset, 4g with good reception at the top.
I did a reset (home and top button held down), took out the SIM and reinstalled it and reset carrier the network settings.  This gave me access to data for a while, then it would stop working again.
Much poking about in the settings menu later, I have discovered that if I turn the "Enable 4G" to off, I get data fine, and it keeps working.
Very odd- any suggestions?  I think this may (though I am not certain) all have happened around the time I updated my carrier settings to EE 31.1
Any ideas anyone?
Re: Mobile data- working on 3G but not 4G
Morning @alldoj
Welcome to the community.
Does this happen in all areas?
If so, are you able to try the SIM card in another phone at all?
If you could this would be great to see if this is the phone or SIM card.
Hope to hear back from you soon 🙂
Thanks, I haven't tried that yet.  I'll give it a go when I get a minute
No problem @alldoj
Let me know how it goes if you can 🙂
Have a great day.
Hi, a quick update
The issue resolved with the recent update to iOS 12.2.2
Thanks for your help
Allan
EE Employee
Hi @alldoj
Brilliant, I'm glad you are now sorted.
I'll let @Leanne_T know 🙂
Cheers,
Lee
