by Manboat Investigator
Mobile data will not work on iPhone 7 plus, shows 4g but can't connect
I have recently upgraded to an iPhone 7 plus. Wifi works, however when out and about it shows 4g/3G but can't connect to anything, send iMessages, load apps etc. Have reset the network settings, turned on and off; but no joy
6 REPLIES 6
Re: Mobile data will not work on iPhone 7 plus, shows 4g but can't connect
Was the phone unlocked or purchased from EE?
Is mobile data active under settings - mobile data?
Purchased from EE and mobile data is active in settings
@Manboat  Have the apps been allowed to use caller data ?
What does it say when you click THIS
( turn wifi off on the device first)
Hi @Manboat
Thank you for coming to see us in the community 🙂
I see @Northerner and @Chris_B have offered some great support to you already with this.
  • Check that the correct mobile number is showing on your phone:
iPhone >>> Settings >>> Phone >>>My Number
Let me know what it says.
Richard
Thanks for the suggestions!
Had to call technical support in the end, something to do with upgrading and one of the systems still being on my old plan. All sorted now
Fantastic news @Manboat
Have a brilliant Sunday.
Richard
