by pwl2706 Investigator
Mobile data usage for NOW TV / Sky Go / BBC iPlayer etc
I am moving to a place where there will be no broadband fixed internet or satellite TV (in the centre of London)
So I need to get mobile data to watch NOW TV, Catchup Services (BBC, ITV, All4, UKTVPlay, and SkyGO) etc)
I would normally watch TV around 160-200 hours per month, and want advice on how much data I will need for this...
I have read some scare stories that NOW TV uses 1-2 GB PER HOUR - does that mean I will need something like 300GB or more per month?
If I need that much - can anyone recommend a non-contract plan with mobile router/wifi for 4G?
As my rent will drop by £300 per month, I have no problem paying up to £200 or more for mobile data...
thanks for your help
Philip
11 REPLIES 11
by Brilliant Contributor
Re: Mobile data usage for NOW TV / Sky Go / BBC iPlayer etc
Centre of London and no access to broadband??
yes, it's actually a commercial property that I'll be looking after under guardianship...
How much data am I using on EE? should give you some guidelines.
PAYG Mobile Broadband Devices will show you the devices & plans available.
thanks for your help..
looking at that I can see it's closer to 300-500MB per hour, assuming say 150 hours per month, that's 75GB - 100GB MAX per month ...
I guess I'll have to look at this one which is £100 for the router, and £60 per month:
4GEE Home Router with 100GB for 30 Days costing £40 per month
that could be really good if I can get it without a contract...
hopefully that'll be enough
What you are looking at is a rolling monthly contract but with just 30 days notice. I pointed you at PAYG devices but now see they are inadequate.
Thanks! You're welcome :)! Glad I could be of assistance.
by Profile closed
Not applicable
@pwl2706, is there no phone line you can use for broadband there? Also, is it possible for you to receive and watch some Freeview tv and record some stuff directly on to a Freeview Recorder box? Or would that seem like going back to the 90s to you?
I am also tempted by the
with the
any opinions or views on that would be very much appreciated
hi,
no, no phone line, and FreeView has disappointed me in the past with it's signal strength in central London...unless I am on a direct line of sight from the Crystal Palace antenna ...
I think I might go with SMARTY and the router from Amazon plus a signal booster...
Hi and welcome to the community, @pwl2706 🙂
As per the link that you posted, our monthly plans go up to 500GB per month.
If you were to go for a 100GB plan and decide that you need more data, you'd be able to add an extra data add-on or upgrade to the next plan up, if you wanted to.
If you go for the 30 day option, you can give your 30 days notice to cancel at any time.
what if I fail the credit check?
any way to get that on PAYG without a contract?
Those plans are the only ones that we have that would suit your usage, @pwl2706.
If you failed the credit check, unfortunately, we wouldn't be able to set the plan up for you.
