by Nate2019 Investigator
Mobile data stopped working
I have an iPhone 7 that was handed down to me by my dad I  have had it for just over a year and just today my data randomly stopped working I still have 3.3GB left to use. I have reset the netwrok settings and that still didnt work. What should I do?
Solution
Re: Mobile data stopped working
It is the same. I will try to reset my phone now.
19 REPLIES 19
Afternoon @Nate2019
Thanks for posting on the community.
Can you make calls and send texts?
What happens when you try and connect to Safari?
Leanne 🙂
Yes my calls and texts work
Hi @Nate2019
Thanks for the quick reply.
What happens when you try and connect to Safari on your iPhone?
Speak soon.
It says safari can not open the page because your iPhone is not connected to the internet
You sure you haven't accidently switched Mobile Data OFF?
My data is definitely on
Hi @Nate2019
Thanks for making sure 🙂
If you go to Settings > Mobile Data > Turn this off and back on again.
Then can you try another network reset on your iPhone.
Let me know if this works for you.
That didn’t work either I think it might be better if I try it in another phone and then see if it works there if it does I may have to get a new phone.
Hi @Nate2019
Is the software fully up to date on the iPhone?
You can check this within Settings > General > About, if a new update is available you will be prompted to update the iPhone.
Let me know if the SIM works in another phone.
Leanne 🙂
Yes I am on iOS 13.2.3
Great thanks @Nate2019
It worked in my nans Samsung S6 edge but still nothing on my iphone
Hi @Nate2019
Thanks for trying this.
Did your dad use the phone on EE as well?
You could try a factory reset on the iPhone after backing up all your data to iCloud.
My dad bought the phone on contract with EE I would check if it is just my phone not liking the SIM card but I can’t die to my phone being locked to ee
Thanks @Nate2019
It does seem like it is the phone as the SIM is working for you in another phone.
Is it still the same after removing the SIM card?
Solution
Hope this fixes the data for you @Nate2019
Got my fingers crossed for you 🙂
It worked thank god. Thanks for your help @Leanne_T
Brilliant @Nate2019
Very happy to hear this 🙂
Have a great day.
Recent solutions
