by billyofdeeping
Mobile data problems
I have plenty of data left on allowance but cant get social media sites to load. Emails work and text and can hotspot for others to use my data...I have switched phone on/off, removed simm, reset network settings, what else can I do?
by billyofdeeping
Solution
Re: Mobile data problems
Fixed it!  Changed content setting from off to strict then turned on/off.  Set back to off now all ok!
by billyofdeeping
Solution
Hi and welcome to the community, @billyofdeeping
Thanks for coming to the community and for sharing the solution to your problem.
Hopefully it helps someone else with social media problems.
