by jemdylanfrankie
Mobile data not working
Hi
i recently upgraded and my mobile data was working fine but now even though it says 3G/4G the internet isn't working? I've tried all the obvious and all the help on google? Thanks
7 REPLIES 7
by Profile closed
Not applicable
Re: Mobile data not working
Hello @jemdylanfrankie what phone do you have? Can you test the SIM card in another phone to confirm a line or device fault? 🙂
Hi @jemdylanfrankie,
Welcome to the EE Community. Smiley Happy
Does the network status checker show any problems in your area?
by jemdylanfrankie
Hi I will be able to put it into another phone later today.
thanks
by jemdylanfrankie
Hi
definitely no problems in this area
thanks
by jemdylanfrankie
It's an iPhone 7 plus sorry
by Profile closed
Not applicable
Hello @jemdylanfrankie is mobile data turned on in settings>mobile data? Has the app you want to use got permission to use it below?
You can perform a network reset by tapping settings>general>reset>reset network settings (you will have to re-enter WiFi passwords after). 🙂
@jemdylanfrankie   Did you try the network reset as indicated by @Profile closed  ?
