by Jojo4 Investigator
Mobile data not working on Iphone
Since my os upgrade I have no mobile data. My phone tells me to switch it in but it’s on. Tech help told me to reset network setting which hasn’t helped. Any suggestions?
Re: Mobile data not working on Iphone
Hi @Jojo4
Welcome to the community. 🙂
Resetting the network settings usually fixes this type of problem.
You may need a carrier settings update. To check this, please go to Settings >>> General >>> About.
If one is available, it will pop up automatically.
Please let me know if that helps.
Hi, thanks for that, but no nothing came up.
Jo
Sent from my iPhone
Hi thanks for that, but no, nothing popped up!
OK, thanks @Jojo4
As this has only happened since the iOS update, it may be worth doing a back up and restore on the iPhone.
Please let me know if that works.
