by MarieMichelle Investigator
Mobile data isn't working
The last week or so my mobile data has just stopped working. Wi-Fi works fine. The little 4G symbol is there with the up and down arrows flashing so it looks like there's data being downloaded and uploaded but I can't load webpages / refresh Facebook or Snapchat etc.
Have tried turning phone on and off, checking mobile data is enabled and had a go at doing the internet settings but nothing is working.
Solution
Re: Mobile data isn't working
@MarieMichelle
Can you try downloading your Internet settings again just to ensure we rule out any apn settings issues.
Have you also logged into your online account/app to ensure you still have some data remaining on your tariff? (you can also send a free txt "ba" to 150 and it will tell you) Can you also make sure the mobile data icon is active on the shortcut page.
Snapchat is a bit hit and miss on EE as other people have posted about issues with this app. I don't know if EE have fixed this issue.
Thanks,
9 REPLIES 9
Have tried turning phone on and off, checking mobile data is enabled and had a go at doing the internet settings but nothing is working 😣😣
It could be one of many reasons.
  • What phone do you have?
  • Does this problem happen in only one location
  • Are you in a good signal area?
  • Are you on EE, Tmobile or Orange?
  • Are you on PAYG or pay monthly contract?
Thanks,
Hi
It's a galaxy S7. Pay monthly. It happens everywhere and the signal is good in those places (has worked fine up until the last week or so). Also on EE. I have enough data left as well. Only used about 0.7GB out of a 2GB monthly plan.
Solution
@MarieMichelle
Thanks,
Hi
I checked on myEE (after a lot of faffing trying to find the right page) and it says I only have 1GB of data on my plan and it's all used up! However on my phone settings it's says I have 2GB of data and only used a small amount of it. Thanks for the help. Better take it into the shop and try to figure things out
Ta x
@MarieMichelle
You can also call 150 as the call is free on pay monthly tariffs. It saves going into store.
Thanks,
EE Employee
Hi @MarieMichelle and welcome to the community.
So I can try and assist, you mention your phone settings says you have 2GB, which settings are these?
Many thanks,
Lee
Hi
I played around with them and managed to sort that out myself in the end. I thought I marked this as solved? Am I going to keep getting people commenting on this?
It's solved people! No more commenting thank you
EE Employee
Hi @MarieMichelle
I was trying to assist with the missing data that you have mentioned in regards to it showing 1GB and you thinking you had 2GB.
Many thanks,
Lee
