by siobhanlaroche Investigator
Mobile data is not working
It refreshed on the 3/11/17 yet it is still not working. It is definitely switched on.
Re: Mobile data is not working
Hi @siobhanlaroche
Welcome to the community. 🙂
Could you try rebooting your device?
Please check your add-on status too.
What kind of device are you using?
I'll do my best to help.
I rebooted my device and no luck! It's an IPhone 6s. I checked my add on and I have all the data available but just can't use it for some reason?
Thank you!
Thanks for checking, @siobhanlaroche.
Please check your area on our network status checker and let me know what it says.
@Christopher_G
It says that they are aware there is an issue in the area. Is there any way of finding out how long it may take to fix this? I’ve had problems for over a week now.
OK, thanks @siobhanlaroche.
I recommend speaking to the technical support team.
They will be able to investigate this and give you some information about what is going on.
Please come back and let me know what they say.
