by Spadger
New Member
Mobile data inadvertently switched on
As a pay-as-you-go user I don't use mobile data but somehow it seems to have been turned on, presumably by an app as there are lots of GPRS events showing in my usage.
One of these apps is called Wallet but I don't remember adding this.  Although I have switched off Mobile data now I suddenly found that, after a week, I had nearly used up all the money on my Simcard.
Is there any way to find out which app was responsible?
Re: Mobile data inadvertently switched on
Hi @Spadger,
Welcome to the EE Community.
Yes, on most phones you can check how much data each individual app is using.
What phone do you have?
